Layouts and Instances
There are two types of layouts available within a project, depending upon the controllers in use.
Default Layouts
Within Layout there is the ability to create multiple views for a project, either different sections of a project, or different views of the same area.
Managing Layouts
New Layouts
The New button in the Layout menu bar will generate a new blank layout
Deleting Layouts
The Delete button in the Layout menu bar will remove the layout from the project
Managing Layouts
The Manage... dialog can be used to keep track of all the layouts in the project and open layouts that have been closed. This dialog box also allows access to the properties for layouts that aren't currently active.
Duplicating Layouts
The duplicate button in the Manage window will create an exact copy of the current layout with new fixtures.
You will be prompted to choose whether to create the new layout with new fixtures or instances of the original fixtures (see below).
Layout Properties
The Properties... button in the Layout menu bar gives access to the properties of the current layout.
Name
Provide a name for the layout to aid identification
Size
Width and height options can be used to change the size of the layout.
The Snap size to Background Image can be used to match the layout size to the background image size.
Background Image and Mode
Select an image to be used in the background, such as a fixture plan.
Background mode can be used to define how the image is displayed.
Background Colour
Select the colour to display in the background of the Layout.
This colour is also used in Scene, DALI Scene and Simulate.
Grid Settings
Grid colour sets the colour of the grid pattern
Grid Spacing defines the number of units to space the gridlines apart.
Grid subdivisions defines the spacing of the minor gridlines
Show grid makes the grid visible or invisible
Snap to grid defines whether fixtures should automatically snap to the grids intersections.
Show Minimap
A minimap can be used to help navigate large complex layouts.
The minimap allows you to zoom in/out and move around the layout while showing a smaller version of the layout:
Instances
Instances can be used with Layouts to add a single fixture to the Layout multiple times on different layouts. This allows the programming to be seen on all layouts where the fixture exists.
Instances can also be used where multiple fixtures are to be controlled by the same control channel. Adding an instance in this case will ensure the fixtures simulate correctly to produce the most accurate visualisation.
Managing Instances
Creating Instances
There are various ways to create fixture instances:
Removing Instances from the layout
Removing an instance is achieved in the same way as deleting a fixture, but all instances of a fixture can be removed without deleting the fixture from the project as a whole.
When deleting the final instance of a fixture, holding Shift will remove the final instance, but keep the fixture in the project.
Locating Instances
Within the fixture browser, a circle icon indicates the presence of an instance of each fixture on the current layout.
No Circle No instances of the fixture within the project
Single Circle (Grey) One instance of the fixture, but not on the current layout
Single Circle (Black) One instance of the fixture, on the current layout
Double Circle (Grey) Multiple instances of the fixture, but none on the current layout
Double Circle (Black) Multiple instances of the fixture where at least one is on the current layout.
Hovering over the instance icon in the browser will highlight the instance/s on the Layout and a tooltip will indicate the total number of instances and the number on the current layout.
Atlas /Atlas Pro Layouts
If you are using a Atlas/Atlas Pro in your project, it will be linked to a Atlas Layout with the same name as the controller e.g. Controller 1.
This layout can be used in exactly the same way as a Normal layout to bring fixtures into the project and lay them out on the Atlas/Atlas Pro Layout. The difference is that these fixtures elements relate to a single pixel in the real world and therefore are exactly 1 pixel in size.
The Atlas/Atlas Pro layout will be used to map any videos or matrix presets to, so the size of the layout should be set to the size of the content output e.g. a 100x100px installation should have a 100x100 Atlas Layout.
The fixture pixels should be laid out to match the real world as this layout is used to map the programming onto the fixtures.
NOTE: The fixture library will only show fixtures that the Atlas/Atlas Pro can support and the fixture browser will only show fixtures on the selected controller.
